On initial login of a new user, I would like the user to reset their windows password. Is there a way to pass that in when using the floating panel?
Reset password
johndavies
Re: Reset password
In the computer management tool, under the user tab, you can check a box to force a user to change his password at next logon.
TSplus support team
TSplus support team
