Chromebook Resolution
JuanMSanchez
Hello: I'm connecting using a Google Pixelbook which has very high resolution. TSApps appear fuzzy and I'm wondering if/where I can change what resolution they/the session run at. I tried changing the Mobile metaview setting in settinigs.js but it didn't make a difference. wondering if there's anything i can do to make the apps appear sharper. thank you.
Re: Chromebook Resolution
probably that FAQ will help you.
https://support.tsplus.net/kb/faq.php?id=74
especially the part "B. Screen size hot-change."
Sincerely yours, JW.
Thanks for the link, juwagn!
Hey duder, check for yourself this site. You may learn some game facts there. Isn't it great? That's right, try this one out.
