Is there multiple monitor support for the Windows Plugin from within a browser?
Thanks,
Chad Newman
Black Mountain Software
Multiple Monitor Support for Windows Plugin
Re: Multiple Monitor Support for Windows Plugin
Yes this setting exist but is hidden in a configuration file.
Locate and open with notepad the remoteapp2.js file in C:\Program Files (x86)\TSplus\Clients\www\software
and set the dualscreen setting to "on". The default is off. Changes are effective when you end your session, refresh your browser and connect again.
// Screen
var remoteapp2_color = '32';
var remoteapp2_full = '2';
var remoteapp2_width = '';
var remoteapp2_height = '';
var remoteapp2_scale = '100';
var remoteapp2_smartsizing = '1';
var remoteapp2_dualscreen = 'on';
var remoteapp2_span = 'off';
// Screen
Fantastic!
Thank you very much!
