OTP or Two-factor authentication with TSPlus ?
I am looking after some way to secure TS Plus session with RDP clients.
Does someone use a Two-factor authentication solution or an One Time Password with TSPlus ? Or anything else ?
I already use Ip white list an Pc name white list
Bebel
Bebel
Re: OTP or Two-factor authentication with TSPlus ?
I found two solutions, working fine:
SaasPass
And
Rohos
SaasPass
And
Rohos
I confirm that Saaspaas works fine with TSplus and a 2FA solution will be implemented soon as an option for TSplus.
Is it possible to use SASSPASS and the reverse proxy/gateway feature in TS Plus together?
Seems I need IIS for SASSPASS but would still need to utilize the HTML5 page for selecting and authenticating to a specific application server during login.
Hi All...
I have signed up for a trial of TSPlus and it's a great tool but 2FA is a non negotiable requirement soon in our company IT remote access policy requirements.
Is there any update on the mentioned 2FA option being built into TSPlus yet? It would be preferable to have it all controlled from within one tool and not have to bolt others on.
Thanks,
durrie.
Thanks,
durrie.
As mentioned previously SaasPass is supported by TSplus as well as Duo.
We created a documentation to help you for setting this up here : https://www.terminalserviceplus.com/doc ... entication
We at Rohos confirm that Rohos Logon Key can be used as 2FA option over TSPlus sessions. Web and RDC sessions are supported.
- Possible Authentication means : OATH OTP, Google Authenticator, SMS, Email or hardware OTP generator like Yubikey;
- Flexible 2FA policy and filtering: By list of users, by AD group membership, by location, by access type: console or remote;
- 2FA control by geographic factor: filtering LAN\WAN connections by IP address;
- Price: 59$ for consumer Windows; or 190$ for Windows Servers; permanent licenses;
https://www.rohos.com/2018/02/13/rohos- ... ntication/
So we also plan to add U2F Security keys support but only RDC based sessions;
albertpinto
- Contact:
No doubt go for SaasPass
Hi, are there any ETA now for TSPlus integrated Two-factor authentication?
i think, with HTML5 Client on public area this is a must..
Thanks,
Uldis
Thanks,
Uldis
the ETA for TSplus 2FA solution would be around christmas. We will let you know as soon as it becomes available
