Custom Icons
Custom Icons
We have a few custom apps that are published through TSPlus. We would like to assign an Icon to these apps as they just have the default stock generic icon. Is there a way to do this that I am not seeing?
Re: Custom Icons
Hi, I am having the same issue. I want to use custom icon for application.
IE : create a url website application, the link works, the icon is blank.
I want to put my own icon.
Thx.
Andre
Thx.
Andre
Re: Custom Icons
Thanks for the clarification! I'll give it a try.
Re: Custom Icons
Some applications will not display their icons properly for various reasons.
You can counter this effect by either publishing the remote desktop or remote taskbar and copy your cocktail of application shortcuts with personalized icon directly to the desktop folder of the user profile. This way the icons will be display properly.
If you know how to script a little, you can also develop a small application launcher with your icon in it and publish it in the admin tool.
