Is there a way to initiate File Transfer PC to Server using code or a hotkey? I know i can use Shift-F12 to open the File Manager but would like to display just the PC to Server dialogue without the user having to use the top menu.
Thanks.
Re: File Transfer PC to Server
If you are connecting with a generated connection client and have redirected local drives you can always use any copy or ftp command \\tsclient\c\your chosen path.
I am not sure about this being possible with the HTML5 client.
you got the answer in ticket 1812195 already.
PS: the new version is already available, the required feature can be executed by shift+f8, but since it is unprevileged action in browser you will need to allow popups..
