Printer compatability list for remote desktop printing?
elementalwindx
Post by elementalwindx » Fri Mar 11, 2016 1:03 pm
Is there a list somewhere showing all the printers that are compatible with your remote desktop software?
Thanks.
Re: Printer compatability list for remote desktop printing?
Post by admin » Fri Mar 11, 2016 4:18 pm
Any printer that is compatible with RDS should work fine with TSplus as it uses RDP printer redirection.
1- Universal Printer :
You will find here will find more detailed information about this in the Remote Printing section of the documentation : http://www.terminalserviceplus.com/docs/
2- Print redirection :
