Hello, does .htaccess work with your web server. If not is there a way to protect the html pages/directory to allow access only from a specific IP or URL?
Basically I do not want everybody in the world be able to hit the index and get to the login screen, only from some IP's
Thank you
.htaccess or protect the html pages/directory
oliversl60
Re: .htaccess or protect the html pages/directory
.htaccess is an Apache file, and TSplus web server is not based on Apache, therefore this feature is not supported. I recommend you to set up your firewall to achieve similar purpose.
