I am not impressed with the file transfer process.
First it comes up with "Please use a generated client (6.4) etc. Even thought that's how I accessed the File Transfer in the 1st place.
Then, I try it again, and the transfer window appears.
The default comes up with C:\Documents and Settings\????\Desktop. It is crucial this should be configurable.
If I type the location in this box it does not display the files. e.g. I type c:\myapp and nothing changes
The only way I can get to the folder where the files are that I want to transfer is to keep clicking the yellow icon below the word Name
Somewhere I read something about Ctrl F8
Where do I read more about this ?
						File transfer
Re: File transfer
ctrl and shift f8 are no longer in use for enabling file transfer and has been replaced with a new transfer feature that now can be assigned to users and groups. You can read more about it here : http://docs.terminalserviceplus.com/file-transfer
TSplus support team
TSplus support team
