I want to execute my programe after successfully login.
I added this in javaconnect.html
var filesdownl="myprog.jar" // java/myprog.jar folder //
but myprog does not execute.
thanks for help
load and execut my prog
Re: load and execut my prog
javaconnect.html should not be edited, I recommend you to compile your java program and publish it using the admin tool or set it up via a logon script.
