we had a server crash and after reboot, TSplus allows only 2 users to connect to the Server.
We tried to uninstall and reinstall TSplus, but the error remains.
While installing, TSplus shows this Message:
We are using Windows Server 2019 for a long time on this installation with several TSplus updates over the last 2 years.
We used the current TSplus release 14.70.5.18 and Server 2019 release 10.0.177763.1971 with all windows updates.
We need a quick solution here, our customer is not able to work.
Regards
Michael
After server chrash, only 2 users can connect
Re: After server chrash, only 2 users can connect
I also tried this hint from another support ticket i found:
https://support.tsplus.net/support/solu ... -same-time
But the problem remains, only 2 users can connect.
I opened a support ticket (#35560) and i hope, that someone from TSplus will work on this ticket on the weekend.
Regards
Michael
Regards
Michael
I had the same and it was because I had installed a Windows "Preview" Update.
Un-install the "Windows Preview Update" and all will work as expected.
All recent Kb's are now supported with today's release.
