hi,
I installed TSplus on Windows 2012R2 with the latest updates. however, I published an Application and I created a shortcut using "Client Generator".
all works fine and I'm able to use the published app. but unfortunately after 3, 4~5 mins it shows the log off circle running and it logs me out.
I checked the event viewer and I found this event ID: 4634, 4647.
P.S: I removed TSplus then re-installed it and still facing the same problem.
Please advise.
RemoteApp logs out every 3~4 minutes
Re: RemoteApp logs out every 3~4 minutes
These ID means that the user initiated a logoff. Try assigning a full remote desktop and use a RDP client instead of the Remote App and try again.
Check also the timeout of active session in the admin tool / session / settings / session management settings
