Doing so will only allow 1 user to login. We learned this the hard way and I don't see it posted anywhere else. Rollback fixes the issue but can take 30-45 minutes.
I've been told it's being worked on and we'll be notified.
Thanks,
Rhett Price
IndySoft
No One should install Windows Update KB4534307
Re: No One should install Windows Update KB4534307
Disable preview windows update should prevent this in the future.
We have complete control over Windows Updates, however we have to keep up for security protocols. We had no reason to think this update would be a problem. Generally our testing is a login of our system after the update. This broke on 2nd login for our customers. We're having to change now the way we do everything.
If we had seen the issue here on the Forum in Announcements or here: https://tsplus.co/microsoft-tuesday - then we would not have had a problem. This is a very serious issue and our customers are enraged with us today. Please please please update your Status pages so this doesn't happen to others.
Rhett Price
CTO
IndySoft
Rhett Price
CTO
IndySoft
We also applied update KB4534307 on server 2016 last night and experienced issues in the morning after reboot. Checked the forum and the issue was the first post. Problem is, 2016 does not allow you to cherry pick updates, or hide updates like previous. What is everyone's work around for this, WSUS ?
