HTML5 Clients doesnt logoff
In newest TSPLUS-Version, 12.60.1.13, non of our HTML5-Clients logging out after closing the Browser Windows.
The windows-Session is only disconnected instead of logging of.
W.send_logoff = true; is not changed
Enviroment: Win Server 2019
Re: HTML5 Clients doesnt logoff
You may need to refresh your client browser with ctrl + F5 to reflect changes of new version.
Thanks for your quick response, Olivier!
This is a complete new install, so the issue persists also in a new/refreshed Browser.
This problem doesnt exist on our other TSPLUS-Servers (< 12.40)
Did you check your disconnection settings ? I don't think we changed much in this regard.
there was no change regarding that setting from html5 client side, probably main office disabled it since it is not html5 feature to react on this command and only server side part from TSplus finally decides it, probably @admin can assign your ticket to TSplus team if you create ticket.
However rather than to rely on this command you should setup lower timeout for disconnected sessions, as example 5000ms.
Sincerely yours, JW.
If i publish for example FloatingPanel with some Apps, it works perfectly via the Connection-Client (Remote-App).
When i access this with HTML5-Client, pressing "logoff" or closing the Browser, the User never logged of from the Server.
Instead the user gets a black screen and cannot relogin anymore.
Then the Session terminated, that is not my goal.
The Session must be "intact", but when a user wants to really logoff, the session should be terminated.
But in 12.60 this is not possible anymore. We need this feature.
Ticket #11959 opened.
That is the main point you should mention in the ticket, that when pressing logoff it wents to black screen and doesn't really logoff. So you could exlude by correct description of problem all wrong assumptions. However you should check firstly if it logoffs correctly with html5 client when you open usual desktop, not any kind of started app, i think that information will be useful for the team to debug correctly.
Additionally you should start second session under different user as admin with visible desktop, start taskmanager and check in taskmanager runnging processes of the another user that didn't logoff properly, if there runs any kind of process in loop and consumes CPU, or kill the processes of that hanging user one by one, and then from taksmanager press logoff button for hanging user and see how it acts, if it it logs off then. I think if the issue is not reproducable elsewhere except your environment then there is no other way around than to check these things.
Thanks for your Input.
What i not understand, when the user X is logging in via Connection-Client and logs off, logoff is successfully.
This is not the case if the user connects over HTML5.
So the logoff button is useless in HTML5?
