I do not know the cause but RDS was using 5.7GB of ram on a 8 GB server (Windows Server 2012). So I restarted RDS Knight and the memory went down to 59 MB. Is there a way to limit the amount of memory RDS Knight uses?
Simon
RDS using using 70% of System memory
Re: RDS using using 70% of System memory
I am using version 4.4.10.30 the memory usage is now 212 MB and climbing. It climbed 5 MB while I created this message.
Simon
Simon
I was able to unblock the TSPlus download site and install the latest update of TSPlus Advanced Security version 4.5.12.17 and the memory useage has been stable for 24 hours at 111 MB.
Simon
Simon
Thank you for your feedback.
