Sometimes connecting dialog stay on screen after connected and assigned application (or TSPlus taskbar) run inside "Show Details" of that dialog (!).
Why is this happening?
Program start in "details" window ?!
Re: Program start in "details" window ?!
Did you find out how to fix this issue, we are getting the same issue on multiple sites. A reboot will correct it for a bit but then the issue will come back again.
Alex
Alex
I do not know what be causing this. Make sure you are using the same release. If you can, create a support ticket and provide with an access to your server and way to reproduce this issue so we can investigate.
