RDS knight
Bruteforce tab.
Server 2012 / Server 2016
Windows Logon audit is not enabled - Logon Failures are not monitored. Click here to repair the feature.
I have to keep on clicking it to repair it. I would like to set this through group policy.
I am enabling the setting here and running gpupdate /force.
Computer Configuration go to Policies node and expand it as
Policies -> Windows Settings -> Security Settings -> Local Policies -> Audit Policy
In the right hand panel of GPME, either Double click on “Audit logon events” or Right Click -> Properties on “Audit logon events”
A new window of “Audit logon events” properties will open. Check “Success” and “Failure” boxes and click “Ok”
I am looking for exact GPO settings to keep this always enabled and logging.
Windows Logon audit is not enabled RDS knight
fakebrains
Re: Windows Logon audit is not enabled RDS knight
You can also activate this strategy which needs to be disabled and is located in: Computer configuration / Policies / Administrative Template / System / Group Policy / Turn off Local Group Policy objects processing.
fakebrains
Thanks.
I disabled the group policy that was affecting it.
