Group Policy - Shutdown Button
dcipher
Post by dcipher » Thu Nov 01, 2018 10:52 am
In the Group policy for Windows 2012 Server you can turn off access to the Shutdown, Hibernate, Sleep buttons which I have always done. However, after installing RDS Knight these settings are not respected. Perhaps that is just a coincidence but now these items are shown. I checked the Group Policy and the policy is still enabled. If I re-apply the Group Policy the buttons disappear until I login in again.
Has anyone else seen this problem and found a way to fix it?
Simon
Re: Group Policy - Shutdown Button
Post by admin » Tue Nov 06, 2018 1:12 pm
Yes this is a normal behavior as RDS Knight does erase all existing GPO settings. We plan on enhancing this behavior in the future.
You can prevent shutdown button from being activated by using the secured desktop feature.
dcipher
Post by dcipher » Sat Nov 17, 2018 12:12 am
I would certainly like the Shutdown, Hibernate and Sleep options policy to be followed so that remote desktop users cannot accidentally shutdown the server etc. It might even be helpful if TSPlus had an option for this in the Admin tool or it was the default setting.
Thanks,
Simon
