Floating Panel - no taskbar
Aquila
Post by Aquila » Wed Oct 10, 2018 4:32 pm
I have setup TSPlus and it does work and I am getting ready to purchase it, but I have setup my users to login using the floating panel and while all programs do run successfully if I minimise an application it does not get displayed on the taskbar, in fact no taskbar is displayed. If I use ALT-TAB I can scroll through all the minimised applications to the one I want.
Any ideas on what would cause the taskbar not to display, I have managed it without issue before.
TIA
Derek
Re: Floating Panel - no taskbar
Post by admin » Thu Oct 11, 2018 10:41 am
If want to have a better behavior for minimized application, I recommend the use of the Remote App connection client.
If you are currently using version 11.60.10.5 then I recommend you to also update to 11.60.10.11 that was released today. This should solve your current issue.
