For the past 6 weeks our users have been reporting that they are getting randomly disconnected from our TSPlus servers while trying to watch training videos.
we have 3 servers using load balancing and running version 11.30.6.12 and this is happening on all servers no matter how many users are connected.
We used the windows client generator to create a remote desktop client and a RemoteAPP client but both have the same problem.
Are there any log files in TSPlus that would give us a clue to what is happening?
I've checked the windows event viewer and cannot find any issues at the time someone gets dropped off.
I've had a ping running from the site pc to each of the 3 servers to see if there is a latency problem.
All 3 servers were pinging normally until the "disconnect" happened.
the server the site connected to had 4 pings in a row show "general failure" and then went back to normal.
The other 2 only had a single ping drop and it was just 'destination unreachable" then back to normal.
We've tried replacing pc's and still have the same issue.
Thank you.
Remote desktop session has been disconnected
Re: Remote desktop session has been disconnected
Streaming video through a TSplus session is not ideal as it consumes a lot of bandwidth, which may explain why you are getting session disconnections. Maybe adding more network card to your servers can solve this issue. I noticed that you are using version 11.30, I recommend you to update all of your servers to latest release as we fixed many performances issues during the last 2 weeks.
