Seamless client
nbatocanin
Seamless client
Post by nbatocanin » Thu Aug 16, 2018 1:53 pm
We have been using TSplus on several servers for a couple of years without major problems. Until recently we used MS RemoteApp for remote connections and we had no problems with it. The problems began with Windows 2016. which limited the number of RemoteApp connections to 15, so we were forced to use the TSplus seamless client.
Immediately, users began to complain that work was much slower - for some reason the seamless client refreshes the image much slower and it gives the impression that it’s much slower than it actually is. Also, many users complain about "alien" effects, such as this one on the image. Is there any way to solve this, and does TSplus plan on working on this?
Re: Seamless client
Post by admin » Fri Aug 17, 2018 5:31 pm
We developed the seamless client during the Windows XP / 2003 era so this connection method is optimized to be used on Windows XP and 7 client operating systems.
With 2008 the Remote App became available and was preferred because remote applications could be minimized directly in the windows taskbar. We are aware of this display issue with this connection and we want to upgrade it because of the ongoing performance issues noticed with remote app.
SaleCar
Re: Seamless client
Post by SaleCar » Sat Aug 18, 2018 11:53 am
We are unwillingly forced to use Seamles because Win Srv 2016 have limit of 15 RemoteApp connections. Can we hope for a solution to this problem?
Re: Seamless client
Post by admin » Mon Aug 20, 2018 11:00 am
We have been working for quite a while on this ongoing issue and we hope to be able to find a solution soon.
