created a exe client with client generator and it got picked by my virus scanner
osi99
Post by osi99 » Sat Jul 07, 2018 6:22 am
i am running a trial ver of tsplus and i created a exe client with client generator and i tried on a windows 10 computer and my virus scanner picks it up has a trojan:win32/Fuery.B!cl
SaleCar
Re: created a exe client with client generator and it got picked by my virus scanner
Post by SaleCar » Sun Jul 08, 2018 10:32 am
We have 6 TSPlus servers and few hundreds clients accessing through the client exe and last days we had many calls from clients because their antivirus deleted TSP client app. Then we had to exclude TSP exe in antivirus on every computer. We welcome if this problem can be solved systemically.
osi99
Post by osi99 » Sun Jul 08, 2018 4:42 pm
i hope they can fix this because i really like this software i am planning to buy the software soon.
Post by admin » Sat Jul 21, 2018 6:41 pm
I confirm that there is no trojan on client side. It is often seen as a trojan because it is an unsigned executable.
There will be a new client generator in the form of a setup that you will need to launch on client side which will definitly solve this ongoing issue.
This should be available with version 11.40 very soon.
Meanwhile you can set on client side an exclusion on the following path : C:\Users\Nameoftheuser\RDP6
