Hello a have problem to run program after reconnect session (taken session).
In me rdp file I have alternate shell:s:"C:\Windows\notepad.exe" but its working only in first login, when I logging from another computer (taken session) its doesn't work. Anybody help ?
Taken session problem to run program
Re: Taken session problem to run program
Check the "Allow users reconnection when sessions are disconnected."
Check also the "Allow automatic reconnections when a session is disconnected."
You can also set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
