Users in Subdomains
Users in Subdomains
Does anybody know if it's possible to assign apps to users in child domains. I tried creating a local group and adding the user to it but it still doesn't think that user has any apps assigned. Thanks if you can help.
Re: Users in Subdomains
Usually when using a multiple domain environment, you would need to open a session with an admin account of each users to assign applications to the group / users of that domain.
What you could try also is edit the AppControl.ini file with notepad located in C:\Program Files (x86)\TSplus\UserDesktop\files
Each applications looks like this in this file, by adding the DOMAINNAME\NAMEOFTHEUSER in the user or group field you will be able to publish your applications to any domain users or groups. However I cannot guarantee this will work as we did not focus much on this particular environment.
[App5]
appname=Desktop folder
path=C:\Program Files (x86)\TSplus\UserDesktop\files\folder.exe
startup=
cmdline=
groups=
users=TSPLUS\Olivier;DATAFUTUR\John
maximized=no
minimized=no
hide=no
all_users=no
[App5]
startup=
cmdline=
groups=
maximized=no
minimized=no
hide=no
all_users=no
Thank you!.. Adding the other domain admins as local admins to the server actually worked perfect.. i was then able to assign apps to the users in that same domain. An email response i received made it look like this wasnt supported saying you could only use local users and domain users of the where the server is attached to:
From: Support [mailto:support@terminalserviceplus.com]
Sent: Monday, May 7, 2018 2:16 AM
Subject: Re: users in subdomains [#4586127]
-- reply above this line --
Dear Juan Sanchez,
Good morning,
Thanks for contacting our support.
TSPlus supports users and groups for the domain assigned to the server, or local groups and users on the server.
Hoping to have responded to your request
Your TSplus Helpdesk Team,
Best Regards
TSPlus Online Documentation : http://www.terminalserviceplus.com/docs
TSPlus Knowledge Base : http://support.tsplus.net/kb
TSPlus Support Team
________________________________________
Dear Juan Sanchez,
Good morning,
Best Regards
TSPlus Support Team
Thank you for your feedback and glad you figured a way to have TSplus work fine in your environment.
Yeah there are two Olivier's in our team so our answers may differ from time to time.
