Applications disappeared
gcersarb
Post by gcersarb » Wed Feb 28, 2018 6:24 pm
Please,
my published applications have disappeared (attached image 1).
In application control the basic icons like the floating panel no longer appear (attached image 2).
What happened? How can I solve?
TSPlus Version 11.10.1.22
Thank you,
Geraldo César Barbosa
Re: Applications disappeared
Post by admin » Fri Apr 06, 2018 7:14 pm
I do not know why you encountered this issue, in this case you will need to re add and assign your applications again. You can prevent this issue from happening again by opening a windows explorer and edit the NTFS right of the appcontrol.ini file in TSplus\User Desktop\files and check the "Read only" box.
