Sharing local drive
hoanghuynh
Sharing local drive
Post by hoanghuynh » Fri Jan 12, 2018 4:40 am
I bought 5 tsplus licenses with remote printing option,
create a client and I marked as options to share the local disco
When running this client on a computer running windows 8, such as local drives, are views on the remote connection.
using this same client on another pc with windows 7, it was not possible to access as local units. There is a setting that I must do to be able to access as local drives.
my version is and 10.40.8.5
Re: Sharing local drive
Post by admin » Mon Jan 15, 2018 4:32 pm
This issue happens if cache from previously generated connection client is present on the client computer. You can edit or delete the cache of previous client with this procedure : https://www.terminalserviceplus.com/doc ... ted-client
If you choose to edit the client settings, check the presence of -disk on parameter.
