Web logon page: How to open the HTML5 client in the same tab
emarsalis
Post by emarsalis » Thu Dec 28, 2017 4:18 pm
Following the documentation provided by TS PLus under "Web logon page: How to open the HTML5 client in the same tab".
We are on version 10.50.10.31. Following the changes to the JS scripts "common" and "common_applications" the text does not match what I have on our server in the "C:\Program Files (x86)\TSplus\Clients\www\software" common and common_applications JS scripts.
Is there an updated script change you can supply? We would like the login page to close once the user is connected to the application server.
adrien
Re: Web logon page: How to open the HTML5 client in the same tab
Post by adrien » Tue Jan 23, 2018 12:49 pm
Are you checking the offline documentation installed with TSplus?
Because it looks like our online documentation is up-to-date: https://www.terminalserviceplus.com/doc ... n-same-tab
It also does not mention a common.js file.
Please check the online documentation and tell us if this fixes your issue.
Adrien
TSplus CTO
