I am publishing a single exe file but when I quit this application TSPlus does not exit. I just see a blank screen until the idle session limit is reached. I would like the TSPLus session to end as soon as I exit the application. How is this done? I am using v10.5.10.11 on Windows Server 2012.
Thanks,
Simon
Session does not terminate when application exits.
Re: Session does not terminate when application exits.
You would probably need a logoff script that kills the process staying alive.
for example C:\Taskkill /IM firefox.exe /F
Today the TSPlus shuts down when the application exits. We have not rebooted the server or done any updates so I can only assume something in the server was causing this problem because now it works as expected so I may never know why it was not working for several days previously.
Simon
Simon
Try to reinstall it. I don't know what else you can do with it
I really like this forum because it is very useful, I always can find necessary information here and it is comfortable even on mobile phones. Thanks for it!
