force a 4/3 aspect ratio on the HTML5 ?
fakebrains
Having a problem with generating PDF's on Server 2016 using Microsoft report writer 2016. It seems to be an aspect ration issue and when printing there are issues with font replacement/font missing/character space compression. When I change the aspect ration on my browser to view everything at 4/3 then the problem goes away. I know its specifically report writer but i was wondering if there is a way to force a 4/3 aspect ratio on the HTML5 browser area, even if there is unusable space.
Re: force a 4/3 aspect ratio on the HTML5 ?
did you try firstly to update to latest available version before reporting the issue?
AdminTool GUI > License (tab) > Check for update
After installing update REBOOT.
Then open locally on server in browser
http://127.0.0.1/w0j41
and go sure you got HTML5 version: v5.45 after update.
Most probably the issue will be gone after update since similar symptoms were already reported and fixed in last patch.
fakebrains
Updated to the newest version and seems to be working fine now. Thanks !!
