Sorry - the subject is probably really confusing.
If you use create a RemoteApp using TSPlus and select the option to open a single app (In the Programs tab), is there a way to NOT show the RemoteApp screen and go directly to the app? (I've attached the screen I'm referring to)
In my test environment, currently the user double clicks a shortcut on their computer, the RemoteApp screen pops up for a couple seconds and then the application (Chromium) opens.
Thanks in advance!
Can you disable the RemoteApp screen when using it for a single app?
Re: Can you disable the RemoteApp screen when using it for a single app?
Sorry this is not possible.
