Remote Control Doesn't Work
bbogedin
Post by bbogedin » Tue May 30, 2017 4:21 pm
Problem:
User remote control doesn't work. Shows the local rdp session to start loading and then says "Unspecified error" with an ok button and closes out. How can I get shadow session to work? Tried this both using the Session Manager and the elevated command prompt script but same error.
Code: Select all
@echo off
set /p session="Enter the Session ID to shadow:"
mstsc.exe /shadow:%session% /control /noConsentPrompt
Note prior to installing TSPLUS I had RDPWrapper installed and it worked fine with remote control shadow sessions. I uninstalled RDPWrap before TSDPLUS installed. I attempted RDPWrapper after as well but still no luck. So I uninstalled RDPWrap again.
Specs:
TSPLUS Version 10.30.5.23 Mobile Web Version 10 User license
OS Windows 10 Pro x64
Workgroup (not domain)
Running as an a local administrator
Local GPO for both Computer and User configurations set under Remote Desktop Services Host to allow remote control without user permission. Ran gupdate /force successfully
Any ideas to solve?
bbogedin
Re: Remote Control Doesn't Work
Post by bbogedin » Fri Jun 09, 2017 4:14 pm
Just following up any ideas? Lots of views but no suggestions on how to fix :(
I have tried a lot of steps but nothing is working.
bbogedin
Post by bbogedin » Wed Jun 14, 2017 10:06 pm
Further investigation discovered it has to do with the recent windows 10 creators update broke Shadow Sessions. Hopefully someone finds a fix soon.
dcipher
Post by dcipher » Fri Jun 23, 2017 12:45 pm
On Windows Server 2016 I have the same cmd file as yourself and it does not work even with a elevated command prompt. However, it does work if I right-click on the icon and choose run as Administrator.
Simon
