REMOTE APP without task bar or floating pannel
Alejandro
Post by Alejandro » Sat May 13, 2017 4:05 pm
Hello, I would like to open an application directly without floating pannel and task bar.
If I remove both from the configuration,but it does not open anything. If enable task bar, or floating pannel work fine.
solutions for only application, closing app... close connection?
If this was not possible, I would remove the background that covers the client desktop, I tried with all the colors ... nothing.
Installed on
Windows 2016 domain server with load balancing
Windows server 2012 as a server for application
thank you in advance... :)
Re: REMOTE APP without task bar or floating pannel
Post by admin » Sun May 14, 2017 4:11 pm
Have you tried with the RemoteApp connection client instead of the seamless ?
This may mean that your application may not be suitable to be published as a unique application. Possibly because it requires a full profile to be created. In order to do so, you need to open a session once with a full remote desktop..This issue can also occur because it got explorer.exe dependencies which is not an issue when a full remote desktop is launched.
Alejandro
Post by Alejandro » Mon May 22, 2017 9:46 am
thank you, but a complete remote desktop is not a possible choice
thank you again.
