Local disk not visible in HTML5 Mode
Alpin
Post by Alpin » Thu May 11, 2017 12:27 pm
We have an application published with TSPlus.
This application allow to save files on disks.
With TSPlus in HTML5Mode, the local disks of the client is not visible with the application.
If we choose TSPlus with RemoteApp, the local disks of the client is visible with the application.
So, how ca wehave the local disks visible in HTML5 Mode ?
Thank you in advance,
Best regards,
juwagn
Re: Local disk not visible in HTML5 Mode
Post by juwagn » Thu May 11, 2017 12:33 pm
http://support.tsplus.net/kb/faq.php?id=50
Browsers don't allow access to local drives, use native clients if you want to access local drives directly.
Alpin
Post by Alpin » Thu May 11, 2017 12:47 pm
ok, tank you for your quick answer.
Best regards
