Hello all,
We use the RemoteAPP from TSPlus, but we like to include Scanning documents and Dymo printing from/to the local machine.
Does anyone have a solution to this problem?
For now I created a small Scanning/Printing program which uses the shared local disk to transfer data. The executable starts both the Scanning/Printing program as the RemoteAPP, this is however not ideal. If possible, I would like to start the local program by the remote program. If I do this now the local executed program will run on the remote desktop, which is not preferred as it is not functioning now.
Q: Is there anyone who already tackled this problem? Or is there someone who has a solution for starting a local program locally via the RemoteAPP.
Koen
Scanning and Dymo printing local machine
Re: Scanning and Dymo printing local machine
You could try the "Open on client" feature : http://www.terminalserviceplus.com/docs ... lient-side
