Microsoft Desktop flashes up breifly before loading app
MichaelH
Post by MichaelH » Wed May 03, 2017 12:51 pm
When loading an allocated app for a user their normal Microsoft Desktop flashes up before switching to their application, anyone know a solution?
Latest version downloaded 03/05/2017
Alan
Re: Microsoft Desktop flashes up breifly before loading app
Post by admin » Wed May 03, 2017 3:37 pm
This issue is related to the use of the remote app connection client. To reduce this behavior, you need to reduce the visual effects on your server.
MichaelH
Post by MichaelH » Mon May 08, 2017 2:58 pm
Hi Oliver
This server is windows 2012 R2 and visually its standard, do you mean choose a more basic windows theme?
Al
Post by admin » Mon May 08, 2017 4:21 pm
right click on my computer and click on advanced system settings, then select the advanced tab. click on performance "settings" and select "Adjust for best performance.
MichaelH
Post by MichaelH » Tue May 09, 2017 10:26 am
Oliver
Thanks this is already set by default not sure if this newer feature (DEP) Data execution Prevention would be best turned off.
Al
MichaelH
Post by MichaelH » Wed May 10, 2017 3:17 pm
Appears this may be an RDP bug on Windows 2012 R2, using Remote App client seems to resolve this.
GCS_IT
Post by GCS_IT » Fri May 12, 2017 12:34 am
admin wrote:Hello,
I'm getting this on Windows 7 Pro using the Seamless client option. I see the welcome screen, then a brief glimpse of the server desktop, and then a ghosted start button, which I can click and run anything remotely, which is not desired.
(3.03 KiB) Downloaded 3863 times
Full desktop is not published. Themes disabled. Everything turned off in visual effects.
Post by admin » Sun May 14, 2017 4:12 pm
This issue is being corrected as we speak and a new version will be available tomorrow.
MichaelH
Post by MichaelH » Tue Jun 06, 2017 2:27 pm
Thanks, seems to be resolved now.
Alan
