Universal Printer only works as Administrator
Ritti
Post by Ritti » Fri Apr 28, 2017 1:48 pm
Hiho,
I just installed TSPlus on a Windows Server 2012 and it works great. The only thing that doesn't work as expected is printing.
I set it to "Select the local printer - local driver included" and if I grant the user admin rights it works. If I remove the admin rights, it doesn't.
Obviously there are some write permissions missing (or maybe execute of some Program) for normal users but I don't know where. I checked C:\Program Files (x86)\TSplus\Clients\www\prints and print (manually created after reading in a forum) and normal users have write access. Local Disks are redirected as expected (can write in subfolders of redirected c:, tested only with one folder, so maybe there is the problem). Where else do I need write permissions?
Help would be appreciated.
Thank you and best regards, Ritti
Re: Universal Printer only works as Administrator
Post by admin » Mon May 01, 2017 11:42 am
I recommend you to update to the latest release to solve this issue.
