Hello!
Is there any automatic way to remove files into C:\Users\username\RDP6\sumatrapdfcache? never delete them by itself?
Regards.
Remove temp files
Re: Remove temp files
You can use this procedure to create a shortcut of the connection client which will delete the entire RDP6 folder content : http://www.terminalserviceplus.com/docs ... ted-client
