Wrong time using Web access
cesare
Post by cesare » Mon Mar 27, 2017 8:18 am
Hello
we are having bad time setting using Web access, for sure after the daylight saving that changed automatically this week-end, on friday it was perfect.
I can tell that accessing the same server using RDC application, time is correct, instead using web access to the same server it is NOT correct.
We have restarted server, but no success.
We are using TsPlus server by a Windows 10 machine version 1607 (build SO 14393.953)
We are using TsPLus 10.10.3.26
Kindly one suggestion.
Thanks all.
Re: Wrong time using Web access
Post by admin » Mon Mar 27, 2017 9:55 am
Open an admin tool, click on the server tile, click on "Session opening preference" and check "Time zone redirection". You will need to logout and logon again to make the changes effective.
cesare
Re: Wrong time using Web access (SOLVED)
Post by cesare » Mon Mar 27, 2017 12:53 pm
Your suggestion solved the issue.
Thanks !!!!!
