Reconnecting - same user name - multiple machines
We are using the same login to our remote app. We login from multiple location in the same building at the same time. If there is a building wide internet outage we notice that machines may not get their specific session back. How can we ensure they get the same session?
Re: Reconnecting - same user name - multiple machines
Check the "Allow users reconnection when sessions are disconnected."
Check also the "Allow automatic reconnections when a session is disconnected."
You can also set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
Is there a way to "User must Reconnect from the Same Device" when the same user logs in from multiple devices?
For these specific options, TSplus AdminTool is just setting the Windows GPOs registries.
If you have set:
- Allow multipl sessions per users
- The disconnected session remains during 10 minutes
- Users will have to reconnect from the same device
I think that Windows will check the device and the user for each request for re-connection.
If it fits, it will allow it.
That would make sense, but I cannot be 100% sure because this is Windows decision to do so (not TSplus one).
Kind regards
John
If you have set:
Kind regards
John
