We are using TSPlus 9.80.1.24 on Win Server 2012 r2. Upon Logins we see this event.
DETAIL -
1 user registry handles leaked from \Registry\User\S-1-5-21-2574512835-602412554-1081805905-500:
Process 1804 (\Device\HarddiskVolume2\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-2574512835-602412554-1081805905-500\Printers\DevModePerUser
Log Name: Application
Source: Microsoft-Windows-User Profiles Service
Date: 3/6/2017 5:05:34 PM
Event ID: 1530
Task Category: None
Level: Information
Keywords:
User: SYSTEM
Computer: NCS01
Description:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards. No user action is required.
DETAIL -
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-User Profiles Service" Guid="{89B1E9F0-5AFF-44A6-9B44-0A07A7CE5845}" />
<EventID>1530</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2017-03-06T22:05:34.773069900Z" />
<EventRecordID>74751</EventRecordID>
<Correlation ActivityID="{B7B68A96-960F-0000-6FEC-B6B70F96D201}" />
<Execution ProcessID="936" ThreadID="13700" />
<Channel>Application</Channel>
<Computer>NCS01</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData Name="EVENT_HIVE_LEAK">
<Data Name="Detail">1 user registry handles leaked from \Registry\User\S-1-5-21-2574512835-602412554-1081805905-500:
</Data>
</EventData>
</Event>
Event Log: Registry Left Open Correction
Re: Event Log: Registry Left Open Correction
This looks like a corrupted user profile or device driver issue, unrelated to TSplus though.
We are having same error with TS 12.40.7.12 on Server 2012r2 with Universal Printer.
Its a standalone Server with local user. No Users profiles setup.
1 user registry handles leaked from \Registry\User\S-1-5-21-1690228915-3420803660-859863675-1004:
Process 2032 (\Device\HarddiskVolume2\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-1690228915-3420803660-859863675-1004\Printers\DevModePerUser
This happens few time daily on separate Users.
Kindly assist.
Thanks.
Kindly assist.
Thanks.
