Virus in TSPlus client.
AadGouka
Post by AadGouka » Wed Mar 01, 2017 9:55 am
One of our clients gets a viruswarning when he starts a TSPlus client. Probably it's nothing,
but I think it's worth a topic. (See schreenshot)
Best regards,
Aad
Re: Virus in TSPlus client.
Post by admin » Wed Mar 01, 2017 10:07 am
This is a false positive.
TSPlus is 100% virus free. We often had some issues in the past with antivirus as we do use some scripting in our code. This is why it is recommend to deactivate your antivirus before installing TSPlus and set an exclusion rule on installation path is also highly recommended.
You will need to set an exclusion rule in your antivirus on the following path : C:\Program Files (86)\TSPlus and C:\wsession
You can also use this link to report this false positive to your antivirus editor : http://www.techsupportalert.com/content ... ll_Vendors
