hide drives for non-administrators only
Is it possible to hide the drives for non-administrators only
Re: hide drives for non-administrators only
Yes, this is possible using GPO.
If you activate the "prevent access to the selected drives" group policy, your users will not have access to these drives at all. Alternatively you can set up NTFS rights to specific folders to prevent access to sensitive data.
More information about the hide drive feature can be found here : http://support.tsplus.net/kb/faq.php?id=29
When setting up group policies you may want to make sure these securities applies only to non administrator users : http://support.tsplus.net/kb/faq.php?id=19
