Hello
we have noticed new strange behaviour in latest TsPlus version 9.50.9.12: for us it is a regression, the previous version we were using in production (9.10.xx) was perfectly working in this case.
1) After the successfull login, using HTML5 Chrome, on startup it is automatically launched our main application.
If user close our main application and launch some other application clicking on left tasktar, then resize the browser windows, we are noticing that it is again automatically launched our main application !! This is obviously not expected.
2) We are also noticing, using TsPlus version 9.50.9.12, that on lower right there are 2 new unwished icons, it seems something related to OneDrive, that we are not using at all + the language selector (see image "LowerRight.png" here attached). This latest is obviously not a problem, but for sure one disturb, because on previous TSPlus version these 2 were not present and all was much more clean.
3) If user is resizing the browser window several time, resizing repeatedly with speed, without waiting the previous browser resize to be completed, the page becomes black (but application can be launched and used) and the task bar application icon on footer right disappear and the next browser resizing no longer works.
See "Resize_1.png" then "Resize_after_many.png"
(I know normally user don't behaves this way, meaning wait that resize takes effect... but this in previous version worked perfectly, now seems no).
Kindly have a check in order to make it better, if possible, for next update.
Thanks in advance.
Strange behaviour on resizing browser windows using TsPlus latest
Re: Strange behaviour on resizing browser windows using TsPlus latest
Hi Cesare,
Not sure about the resizing issue, since we only have two users who use html5 daily on Mac - and they don't resize their browser.
But the systray icons can be hidden via AdminTool > Applications > Customize Taskbar > [X] Hide systray icons
Hello
thanks for the reply.
Your suggestion solved me the point 2 of this thread (2 new unwished icons in systray at bottom right bar), thanks for it.
But the problem of the HTML5 resizing windows (other 2 points in this thread) are not appening only in MAC browser: I have just tried using Chrome on a fresh new Windows 10 (anniversary updated windows 10) and we noticed the same problem as posted.
I can tell it is not only our TSPLUS setupped on our server, just tried also your demo at http://demo.tsplus.net/software/html5.html and after "playing" with resising for a while, after 1 minute of resizing I got the same black windows as mine, with also applications icons on systray at bottom right bar disappeared (see the screenshot just taken from your demo site: "demo-tsplus-net-software-html5.gif")
I can re-confirm that on previous version of TSPLUS we were using all the points written in this thread was working perfectly.
Thanks in advance.
Thanks in advance.
