I unistall tsplus to install an older tsplus version, but now i can install or unistal i recibe error...
TSplus is already installed...
i reboot the pc sometimes.
Unistall TSPLUS
Re: Unistall TSPLUS
Follow these steps :
download this uninstaller first : dl-files.com/Uninst.exe and reboot.
If this does not work then follow this procedure :
1- Open a control panel and manually uninstall the Universal printer.
2- Rename and delete if present the C:\wsession and C:\Program Files (x86)\TSplus if present.
3- Make sure no users are connected, then uninstall TSplus, reboot your computer.
If these steps did not work then download and install a fresh setup before restarting above procedure : dl-files.com/Setup-TSplus.exe
I recommended you also to deactivate your antivirus before installing/uninstalling TSPlus
TSplus support team
TSplus support team
