keytool.exe not found in 9.40.8.4
hansen
Post by hansen » Fri Aug 05, 2016 4:30 am
I can't manage the letsencrypt certificate - it says can't find keytool.exe, but using Process Monitor it's only looking in C:\keytool.exe
I'm using Java 8.101 64bit on 2012R2. The certificate manager was working fine about two weeks ago, when I last checked.
PS. Thanks for not resetting the GPO anymore, but I still need to re-save settings after upgrade in Web > Web Portal Design to keep the background I've chosen.
adrien
Re: keytool.exe not found in 9.40.8.4
Post by adrien » Sat Aug 06, 2016 9:41 am
Thank you for reporting this issue to us. It looks like our work to plan for Java upcoming version (Java 9) did cause some regression.
Could you please download http://dl-files.com/FreeCertificateManager.bin and copy it on your server in "C:\Program Files (x86)\TSplus\USerDesktop\files"?
This should fix your issue - please confirm so we can integrate this fix in our next release.
Adrien
TSplus CTO
hansen
Post by hansen » Sat Aug 06, 2016 2:17 pm
Thank you Adrien, that fixes the issue.
