Hello
TSplus's software very beautiful and Nice.
In particular there was full of functions that you can use.
The files are on drive C:\
For example:
C:\Program Files (x 86) \TSplus\Clients\www\software\inside.html
C:\Program Files (x 86) \TSplus\Clients\www\software\html5\settings.js
But there's a problem.
Once you update, you need to make any changes without knowing where he was, and what the benefits of plug-in
Sometimes updates the customer doesn't want them,
Only damage
Need to give two things:
1 have an option for setting
Yes/No.
2. where the work changes that work setting up the TS server, that not a few minutes,
It can be hours, days.
It all depends on how the system is built
Hopefully you understand my needs.
Thank you very much
meir
A problem with regular updates
Re: A problem with regular updates
You are correct, there is still much to be done to save some of the advanced configuration files when updating TSplus to the latest release.
As a workaround, you can use this procedure to backup the most important configuration files and restore them easily :
Open an admintool, click on the server tile tab, then click on locate "Backup your server parameters". everything is saved in a newly creater folder C:\Backupparam
You can now uninstall and reinstall TSplus on this server, and click on "Restore your server parameters" to restore everything.
