Inquiries and problems
meir
Post by meir » Wed Jun 08, 2016 9:15 pm
Peace,
I am very interested in the issue of acquisition of TSplus,
But I have some problems I ask if you belong to resolve them.
1. In closed Hcrtsiih client browser, it is the transferor to the OFF position,
But there are two options 1. Advanced Idle shows that it is always open. 2. If you cancel the last display of connected users, so he takes it completely from the server.
2. Is there a possibility to shorten the working table opening far more quickly, which means the bar will progress more quickly, or perhaps replace the black background to something else, it takes time of 51 seconds, which is very long for my clients.
3. I have another problem with security, I see I entered with no one using them information, with the IP address of the one set up by someone else, and I am terribly afraid that a loophole at the TSplus.
meir
Re: Inquiries and problems
Post by meir » Thu Jun 09, 2016 11:25 pm
bouncing
It is very urgent to me
Post by admin » Fri Jun 10, 2016 9:10 am
I'm sorry, but I do not know that Hcrtsiih browser you are talking about. Have you tried using any well known browser such as Chrome / firefox ?
Regarding the security issue you are talking about, I believe you are not using the latest release which is 9.30. So possibly updating will solve your issue.
Experiencing a slow behavior within your published application can come from multiple cause.
1- When a few users do log on and the server starts to hang, open a task manager and click on the process tab. Sort
2- Sorting processes by CPU usage can help to isolate who or what is consuming the most CPU usage.
3- Sorting processes by memory can help to isolate which process is using the most memory.
4- Sorting processes by GDI/Users object to isolate which process is using most objects. Some application may cause servers to hang because of this Windows limitation, more information about this can be found here : blogs.technet.com/b/markrussinovich/archive/2010/02/24/3315174.aspx
5- Right click on "My computer" and click "Manage", then check out the system and application event log. They can also give you some information on where the problem is located.
One another important matter to check is to disable the WMI service in the service windows management tool (services.msc). This service is known to slow down performance of servers.
