Since the update 9.30.5.30 when installing the RemoteApp plugin (or with the auto update when connecting) we get the following error:
We reproduce the issue on two separate systems.
While troubleshooting, we got to the conclusion that the error was caused when downloading in HTTPS.
If we download the package in HTTP we have no issue... Same thing if we do a copy/paste with the file.
Digital signature of "Setup-RemoteAppClient.exe" Download from HTTPS:
Digital signature of "Setup-RemoteAppClient.exe" Download from HTTP:
It's a huge problem for us, a quick help would be greatly appreciated.
RemoteApp Install/Update problem since 9.30.5.30 [Solved]
Re: RemoteApp Install/Update problem since 9.30.5.30
It does the same thing happens with 9.30.6.3
When you try to install the module on windows 8.1 x64 writes "it is impossible to run this application on your PC. To find the version for your computer, contact the publisher"
Still the same with 9.30.6.5...
I believe this issue has been fixed this morning. Please update and refresh your browser to solve this.
The patch 9.30.6.8 did correct the problem.
Thank you!
Thank you!
