hello,
how to connect to 'console' session with tsplus?
I use a software "gemalto classic toolbox" but it can only work in console mode in order to use a certificate on a usb key.
I can log into 'console' session using teamviewer but I would like to use tsplus instead.
my server is windows 10 64bits with tsplus 9.30.5.7
regards,
Bertrand
Re: connect to 'console' session with tsplus
You should be able to log in a console session by using the session manager available in the server tile of the admin tool. A warning is sent to the console session asking you want to allow a remote control of the session, the user working on the console will have to click "yes" in order to allow this.
More information about this can be found here : http://www.terminalserviceplus.com/docs ... management
thanks
it is possible to disable the warning prompt?
there is nobody in front of the console session.
If your Windows 10 server is a Pro edition, you can use gpedit.msc to locate and activate a group policy for this purpose.
Browse through Computer Configuration / Administrative template / Windows Components / Remote Desktop Services / Remote Desktop Session Host / Connections / Set rules for remote control of Remote Desktop Services user sessions
and set to "Enabled", Full control without user's permission.
