Printing, choppy
RoyB
Printing, choppy
Post by RoyB » Mon May 09, 2016 1:18 pm
Hey Guys,
One of our client's is facing an unusual problem, they are getting choppy image and unclear letters when they print from universal printer to local printer. I uninstalled adobe reader and installed Foxit, but still facing the same issue. Printer drivers are same on local as well as remote box. How can I fix this issue?
Roy
Re: Printing, choppy
Post by admin » Mon May 09, 2016 4:51 pm
Are you using the latest version of TSplus ? If not I recommend you to apply the latest update and generate a new connection client.
1- Universal Printer :
You will find here will find more detailed information about this here : http://www.terminalserviceplus.com/docs/
2- Print redirection :
RoyB
Post by RoyB » Tue May 31, 2016 3:07 am
Thanks, followed the steps above and it did help.
Roy
